2 members (TUTS 59, 1 invisible), 192 guests, and 4 robots.
Topics128,196
Posts1,057,395
Members48,469
Stovebolt Photo Moderator
A friend of mine has a 1946 GMC truck in a garage that needs to be moved. His late father dismantled the front end and he can't find bearing numbers to put it back together to move it out of a garage he is losing. Can anyone offer a bearing number from a NAPA or Rock Auto for a 6-lug 46 to get this thing back to gether to roll onto a trailer?
The truck has stock spindles. He doesnt knoiw if it is a 1/2 ton or 3/4 ton - but like a say it has 6 lugs.
Many thanks - Joe
1947 - 3800 dually known as "Deadwrench"
Link to a few photos
In this world there are givers and takers. The takers eat well, the givers sleep well.
'46 GMCs would have a model number on the "caution plate" (that's what the Master Parts Catalog calls it) under the hood on the right hand side of the cowl. 1/2 ton model numbers on the tag would start with CC10x or EC10x, where x = 1 = 115" wheelbase or x = 2 = 125 3/4" wheelbase. 3/4 ton '46 trucks would have a model number of EC152 and were only available in a 125 1/4" wheelbase.
bearings changed between the CC and EC models, so need to know that before we can zero in on the bearing numbers.
Bill, would the 6 lug wheels not be a reliable indicator for a half ton? Perhaps GMCs had 6 lug 3/4 tons.
RonR
RonR
1970 340 Duster
1964 CJ5
RonR
What is left of my knowledge runs out with the pre-1947 models. Everything I come up with before that is just reading the Master Parts Book. And in this case the MPB shows two different diameter bolt circles that have 6 lugs.
Thanks Guys - I'll get back to you and see if we could find numbers on the cowl tag
Joe
V
VEW Offline
V Offline
Joe-you might want to ask Phil,TrknGMC.
My 41 has TF axles, so I’m no help.
~ Victor
1957 3100 - moved on
The two 6 lugs front hubs use the same bearing. Hub 369963 100AC,CC,EC,FC. 150AC, CC casting #599218 and hub 3694768 100-22,100-24 casting 3694768. The parts book doesn’t list a hub for the 150EC? Check the casting numbers, if 559218 the front inter bearing is 909052 (B52) outer 909001 (B01). Oil seal 3656536.
Check Rock auto, eBay, Filling Station and NAPA $$$ they have them.
Hub 3683232 8 lug 150FC casting # 3683232
Jim: My MPB (revised December 1953) has 150 EC hub as part number 3680898, but it doesn't list bearings for that hub. Earlier 150s AC and CC used the same set as 1/2 tons while FC and newer used the 909026/909027 set.
