5 members (Bill Hanlon, JW51, Phak1, Ponchogl, Hotrod Lincoln), 144 guests, and 4 robots.
Topics128,268
Posts1,058,376
Members48,485
#156152 12/02/2005 4:14 AM
One of the tools that I don't have is a torque wrench. Just never could justify it till now. I'm doing a frame up on my 52' AD. Have now turned the corner an begun the rebuild. There are probably a zillion things that could get a specified torque. Question is (actually two); 1/2" or 3/8"". and what should be the spread range? Oh, and I will be getting the 'click' adjustment type. Craftsman has a 3/8" 10-75 lb. that, to me, seems appropriate. What do you think? :confused:
#156153 12/02/2005 5:04 AM
would go with one with a range up to 150, most of your torque requirements will be in the mid range and not put a strain on the wrench, look around the local area to find a place for cal. good luck on you project. most of mine are snap on. send them in at least once a year for cal.
Drive with Pride. mike j
family pic
#156154 12/02/2005 1:51 PM
1/2" is what I use.
1954 GMC 1/2-ton Longbed
1971 Pontiac LeMans Sport
#156155 12/02/2005 4:30 PM
By mid range, do you mean 50-100 lbs.?
And what would I have to put 150 lbs. of torque to anyway?
#156156 12/03/2005 2:22 AM
most of what i use is 1/2in drive for lbs, and 3/8 for in.lbs. most of what you will deal with will more then likly be from 35 to 90. this puts you in mid range for your wrench. after using it i allways reset the wrench to 0 so that their is no pressure left on the spring sets. their will be a few requirements for torque over 100 but not very often. take care
family pic
#156157 12/04/2005 4:08 AM
Former Workshop Owner
It depends on what you want to tighten. I would buy a 1/2" drive, you can always buy a 1/2 to 3/8" reducer. Also, I think that you will get a higher range that will be handy for torqing engine parts, like head bolts.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
#156158 12/04/2005 4:52 AM
I started with a 3/8 click many years ago and it has served well. The only other torque wrench I needed was a 3/4. I recently bought a 1/2 click wrench. It isn't that I can't pull a 75 pound torque with the 3/8. It's that leaning over a fender of a truck pulling 75 pounds on 292 will be much easier. My 2 cents
Larry
I don't own a vehicle that isn't old enough to drink.
#156159 12/10/2005 7:40 AM
a few good thoughts on tq wrench's, keep in mind that if you buy a bigger lb's type it isnt as accurate in the lower ranges,as most tq wrenches are accurate in the middle of the range it works in.this is why most of us use at least 3 diff sizes to meet our needs, heres one my students used to do all the time DO NOT click a click type more than once as this will usaully increase the torque applied.ive tested a [censored] of wrench's and found that the craftsman are pretty acurate and easy on the pocket book. soory but my spellers broke
I'm still around.
Moderated by  MNSmith
