6 members (MRMEROTH11, cmayna, David Bush, Hanks custodian, walter74, 1 invisible), 53 guests, and 3 robots.
Topics128,056
Posts1,055,800
#1561321 10/21/2024 3:12 AM
What was the correct interior color on a fawn or gray 1965 C10? Was it also the metallic beige?
1965 Chevy C10 Longbed Fleetside
Kevin, From a quick look in the 1965 Chevrolet Truck Data PDF the below extract shows only 3 interior color choices (see below). Just my best guess, but I think the color your are looking for to go with your Fawn or Gray exterior is the "Fawn" indicated in the snapshot. If your do a little web searching you can find color chips and paint codes in various places that will better show the actual color involved. Jim Carter offers PT-215 Interior Paint Metallic Beige as what should be correct for your interior. Hope this is helpful. smile
~ Dan
1951 Chevy 3 window 3100
Thank you. So I guess a fawn interior makes more sense than red or aqua for fawn or gray exterior.
Moderated by  ndkid275, Phak1
