| | | Forums66 Topics128,181 Posts1,057,191 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | Be cautious about falling for popup ads on places like Facebook, and other platforms that cater to the bots who spy on your "social media" searches. A little over two months ago, I fell for a slick video ad on Facebook for a set of spring loaded cable assists for raising and lowering trailer ramps. Since I extended the drive-on ramps on one of my trailers, I've needed a second person to assist me in raising the ramps after loading up a vehicle. An online seller called "Full Parts and Tools" seemed to have just what I needed, so I ordered a set. 6 weeks later- - - -no delivery! I finally found a "customer service" contact, and started rattling cages- - - - -got a bunch of mealy-mouthed excuses. I began a campaign of comments on every ad I could find from the company, accusing them of being scammers, and they would delete each comment within a few hours. "Customer Service" finally blamed one of their vendors, "Car Home Depot" for botching up the order. Two days ago, fully two months after I ordered and paid for the merchandise, it finally arrived. I haven't opened the package to see if it's actually what I ordered (or if it will work "as advertised"), but "Buyer Beware"- - - - -if you happen to see an ad from either company and get tempted to do any business with them! Jerry
| | | | | Joined: Jul 2018 Posts: 279 'Bolter | | 'Bolter Joined: Jul 2018 Posts: 279 | Say, Jerry, what do you think of the metal shears that attach to a drill motor that I am seeing ads on youtube? I suspect that there is an old, quality version of this tool and that the ads are targeting people like me who are impressed by the demo video, but that the tool might be pretty shoddy quality. Looks like a great tool, though! https://www.peachloft.com/products/electric-drill-metal-shears-cutter-nibbler
~Charley 1954 Chevy 3100 with 235“Bud”Follow along in the DITY1963 Chevy half ton stepside short box 230 1954 GMC 3 ton 302 And several more Chevy camper and work trucks 1979 1987 1996 | | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | It's probably OK for something about the thickness of metal siding or tin roof panels, but don't try it on body metal. Back when I ran a high school body shop we had a drill motor with a scissors-type shear clamped to the front that did a pretty good job on bodywork if the cut was straight or slightly curved, but it was much sturdier-looking than the one in that ad. Getting it manufactured, shipped from China or some other offshore factory, and selling it for less than $25.00 ought to give us a clue about its quality! Jerry
| | | | | Joined: Jul 2018 Posts: 72 'Bolter | | 'Bolter Joined: Jul 2018 Posts: 72 | Beware. I fell for metal shears, they looked like they cut great, they were cutting circles in the steel panels like they were paper. Well they cut circles because you couldn't cut a straight line if your life depended on it. Yep they got me. | | | | | Joined: Feb 2016 Posts: 1,995 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,995 | If you need a drill mounted shear, the only brand that is worth looking at is Malco.
| | | | | Joined: Feb 2019 Posts: 4,511 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,511 | I also fell for those drill attachment sheers that punch out little crescent moons.It had no problem with 18 gauge sheet metal but I couldn’t follow a line, straight or curved to save my life. Luckily I bought it on Amazon so I could return it.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: May 2015 Posts: 11,164 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,164 | I have used one of the sheet metal nibbler drill attachments that Phil described with good results. Following a line was a little challenging, but doable if careful. It's double ended, and I haven't even used the second end.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | My only complaint with the Nibblers that cut the little crescent moon pieces is that those little sharp pieces go everywhere and are a pain to clean up, to the point I stopped using it. I use electric shears that cut a 1/4" wide piece that rolls itself up as you cut, a cut-off wheel, a Sawzall or hand snips. Mike B  | | | | | Joined: May 2015 Posts: 11,164 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,164 | Yeah, when I used the nibbler, I was always picking the sharp crescents out of my shoes.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | I was searching for a narrow belt profile sander. Messages with AI photos were sent to Messenger through Marketplace. A vendor had a slick attachment for converting my chainsaw to a 3/4” profile belt sander.
He wanted 600.00 and change and had an introductory offer for yet another attachment- a grinder attachment on sale for 150.00.
Gheesh. Just what I want, a pull cord exhaust and oil spitting sander on fresh sheet metal - indoors. No worries though - just disassemble and then assemble the grinder attachment to clean up the metal….after I recover from carbon monoxide poisoning. | | | | | Joined: Jul 2018 Posts: 279 'Bolter | | 'Bolter Joined: Jul 2018 Posts: 279 |
~Charley 1954 Chevy 3100 with 235“Bud”Follow along in the DITY1963 Chevy half ton stepside short box 230 1954 GMC 3 ton 302 And several more Chevy camper and work trucks 1979 1987 1996 | | | | | Joined: Feb 2025 Posts: 57 'Bolter | | 'Bolter Joined: Feb 2025 Posts: 57 | Heard a guy got an amazing deal on a hand held drill Vendor sent him a picture of drill.
I have picked up a few non-elec/moving parts items from Temu. Prices are good, products were decent | | | | | Joined: Jul 2021 Posts: 214 'Bolter | | 'Bolter Joined: Jul 2021 Posts: 214 | I bought my inflatable paint booth from Vevor. Took about 3 weeks from China, and it’s held up so far. About half the cost. Other than occasional tools from Harbor, it’s the only direct purchase from overseas…but most everything is made/assembled over there.
Chip
'Rusto-Mod' '51 Chevy 3600 5 window | C4 Corvette front/rear suspension & drivetrain | everything else looks old and stock '92 GMC Sonoma GT #15 of 806 '91 GMC Sonoma GT Extended cab 1 of 1 Trucks, Trucks.....and more Trucks | | |
