1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
We have a saying at work,"if you barrow a tool once its time to buy your own."
I had to barrow a torque wrench 10 times this week at work.Sadly this is one of the few things i dont have.
Any suggestions for a good quality one at a fair price.(1/2" drive)
The tool mankoolkar should be along some-time.
I would suggest spending a little extra for quality and it will have a better resale value as well if you ever find you don`t use it anymore frown .
SnapOn makes good ones that you can't afford. Usually you can find a decent Proto or SK at the pawn shops. The Kobalt line of tools that Lowes carries is made by SnapOn. They show a 1/2" for $115. Lowes web page
Keep away from the oriental imports, they won't last in your line of work.
Fred
52 3600
69 C-10
Well, i went and did it.Bought one off the truck cause i hate barrowing tools.1/2 in.drive,flex head,250 ft. lbs. 1 yr. warranty and free calibrating if needed. Whent with mechaniacs suggestion and spent a little extra for quality.
Thanks all.
Moderated by  MNSmith
