2 members (Gdads51, Flint48),
165
Mod | | | Forums66 Topics128,088 Posts1,055,995 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 46 Member | | Member Joined: May 2001 Posts: 46 | We have a saying at work,"if you barrow a tool once its time to buy your own." I had to barrow a torque wrench 10 times this week at work.Sadly this is one of the few things i dont have. Any suggestions for a good quality one at a fair price.(1/2" drive) | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | The tool mankoolkar should be along some-time. I would suggest spending a little extra for quality and it will have a better resale value as well if you ever find you don`t use it anymore  .
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | SnapOn makes good ones that you can't afford. Usually you can find a decent Proto or SK at the pawn shops. The Kobalt line of tools that Lowes carries is made by SnapOn. They show a 1/2" for $115. Lowes web page Keep away from the oriental imports, they won't last in your line of work.
Fred 52 3600 69 C-10
| | | | | Joined: May 2001 Posts: 46 Member | | Member Joined: May 2001 Posts: 46 | Well, i went and did it.Bought one off the truck cause i hate barrowing tools.1/2 in.drive,flex head,250 ft. lbs. 1 yr. warranty and free calibrating if needed. Whent with mechaniacs suggestion and spent a little extra for quality. Thanks all. | | |
