8 members (walter74, TexasJim50, MarkT, Gdads51, Hotrod Lincoln, Tinker5, MNSmith, 39Master85),
132
Mod | | | Forums66 Topics128,164 Posts1,056,978 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 2,329 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,329 | Getting ready to put the rear axle back together on the 54 .My question is what is used to seal the thin gasket opposite side of the rear axle cover gasket . | | | | | Joined: May 2015 Posts: 11,139 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,139 | Whatever your favorite gasket sealer is. I used Permatex No.2 that I've had for years.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2010 Posts: 2,329 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,329 | Thanks just want to use something that is decent I don’t want to do this one again .And they even sell it in my city bonus. | | | | | Joined: Feb 2004 Posts: 29,865 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,865 | Permatex Super 300 has been my first choice for 50+ years. www.ebay.com/itm/281653030094?Jerry
| | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | I use High Tack to stick the gasket to the housing while I put the punkin in. I also use a couple of studs to guide it in. Otherwise it's all too easy to tear the gasket as you roll it off the jack into the housing. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Feb 2005 Posts: 1,673 'Bolter | | 'Bolter Joined: Feb 2005 Posts: 1,673 | Getting ready to put the rear axle back together on the 54 .My question is what is used to seal the thin gasket opposite side of the rear axle cover gasket . Oh good. I was going to post a thread asking about the gaskets. I have a set of two - one thin as paper and the other thicker. I wasn't sure what side each go to, looks like the thicker gasket goes to the rear with the cover. Thanks!
~ John in Utah 1946 1/2Ton w/4-speed manual transmission w/1960 235 engineHere We GoFollow in his DITY Bay- If you think about it, it has been one year ago today!
