4 members (rfs56trk, Hotrod Lincoln, dgrinnan, Otto Skorzeny), 108 guests, and 2 robots.
Topics128,164
Posts1,056,968
Members48,458
#1560300 10/09/2024 6:52 PM
Getting ready to put the rear axle back together on the 54 .My question is what is used to seal the thin gasket opposite side of the rear axle cover gasket .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Whatever your favorite gasket sealer is. I used Permatex No.2 that I've had for years.
Thanks just want to use something that is decent I don’t want to do this one again .And they even sell it in my city bonus.
"The Journey"
Follow in the DITY
H Online: Content
Permatex Super 300 has been my first choice for 50+ years.
www.ebay.com/itm/281653030094?
1 Offline
I use High Tack to stick the gasket to the housing while I put the punkin in. I also use a couple of studs to guide it in. Otherwise it's all too easy to tear the gasket as you roll it off the jack into the housing.
1951 3800 1-ton
In the DITY Gallery
U
U Offline
Oh good. I was going to post a thread asking about the gaskets. I have a set of two - one thin as paper and the other thicker. I wasn't sure what side each go to, looks like the thicker gasket goes to the rear with the cover. Thanks!
~ John in Utah
Here We Go
Follow in his DITY Bay
