Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Shade Baby, 55shaker, Pre '68 Dave, 1 invisible), 106 guests, and 3 robots.
Topics128,277
Posts1,058,453
Members48,490
I'm having some work done to my 55.2 GMC, and the guy doing the work was wondering about the curved support rods in the engine compartment. They run from the frame near the lower radiator support to the top of the firewall, one on each side of the engine .I know they have a name but I can't remember what they are called. He also wondered if they are needed. Seems like years ago I read that they were only on the 55.2 and not later years. My questions are, what were they called and are the needed? Thanks.
Last edited by Gdads51; 09/05/2024 2:15 PM. Reason: add descriptive detail to title
1955 Second Series GMC
"Done - A 50 Year Journey"
Follow in the DITY
-- No one said it was going to be easy
rbs56, I can't answer all of your questions as I have no way to confirm what these supports would have been called. Someone with access to the correct year GMC Master Parts Book may be able to help. Perhaps "Support - cab or cowl"??? I did some web snooping and came across a couple pics showing the support tubes I believe you are describing. One pic is noted to be a GM pre-production 1956 GMC Pickup with a V8 (1st pic below) and the second was described as a stock 1956 GMC Panel with the 6 cylinder (pic 2). Best guess is these were installed in at least 1955.2 and 1956 GMC's, but again I have nothing to confirm that beyond the pics I found.
As to them being needed, maybe yes/maybe no??? I saw lots of pic of similar year GMC trucks without them, but some engine compartments that hadn't been cleaned up/painted still showed where they had been mounted to the firewall. If you decide to remove them, don't get rid of them IMHO. Either keep them for potential reinstallation at some future date, or offer them up to fellow 'Bolters in the Truck Parts For Sale forum. smile
~ Dan
1951 Chevy 3 window 3100
My '57 GMC 102 V8 had factory "Kudu Bars". I think that all 55.2 thru at least 57 GMC cabs had the cab studs for mounting the bars. I rummaged through the 55.2-60 GMC Master Parts Book and couldn't find the supports in either section 10 (Sheet Metal), 11 (Frame) or 23 (Body).
I'm wondering if the kudu bars were maybe an option on the trucks, my truck seems pretty well optioned out, except for the v-8 and automatic trans. it has all the other goodies.
Follow in the DITY
Just found GMC Truck Service Bulletin T-3-068 titled "KUDO HORN" STABILIZER, published Feb 15, 1956. I'll post it once our forum's attachment manager recovers from the latest update.
The 1960 GMC Master Parts Book does list the part numbers (there is a different left side part if you have power steering), but does not show the parts.
My 1957 GMC 150 has these.
I always assumed that the Chevy and GMC cabs were the same, with very minor differences.
I wonder why GMC cabs got these and Chevy did not.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
GMC's were built stronger for the "professional", where the more affordable Chevrolet's were built cheaper for the homeowner/small business types.
The big GMC trucks from 1955-59 (and maybe other years) also had door wedges to keep the doors from opening when the cab twisted. They also used a three piece big back window where Chevrolet used one piece for their Big Back Window, this also helped make the cab stronger.+
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Bill, thanks for the info. That's way more than I've seen before on the Kudu bars. The VIN on my truck has the "Y" so I'm having the bars re-installed. I am the guy who is keeping things as original as possible. If the next owner wants to modify things, he'll have free reign. Thanks to all for the help.
Follow in the DITY
Just a follow up, I had the Kudu bars reinstalled. The guy told me they had been fighting with the gaps on the doors to front fenders. After installing the bars, the gaps were perfect. Maybe they help with more than just steering.
Follow in the DITY
I put a steering stabilizer shock on my ‘57 Chevy 3200 and it helps a lot with steering wander, but maybe these Kudu Horn stabilizers could be added to a Chevy also. Cab, door, fender gap could always use a little help too.
1957 Chevy 3200
Daily Driver
PS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights/backup lights/interior courtesy lights.
Follow in the DITY
