Rubber gaskets that sealed the inner to outer fender joints. You can find reproductions offered by many vendors. They are included in this Jim Carter offered front fender gasket set FP119.
~ Dan 1951 Chevy 3 window 3100 Follow this story in the DITY Gallery "My Grandpa Carl's Truck and How it Became Mine" 1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
Probably a masticated rubber splash shield or something similar. I'll look on my truck and see if there's anything remaining.
1950 Chevrolet 3100 (Ol' Roy)
Anti-squeak stuff. It's a rubber U-shape that fits over the edge of the inner fenders to fill the gaps.
Jim Carter has it available as a package for both the inner-to-outer fenders and inner fender to cab anti-squeak (which is just tar-paper). Their PN FP119.
[on edit] I spent too much time hunting the part number down. Dan got there before me.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
