3 members (Wheelie, Ole49GMC, GMCJammer51), 98 guests, and 3 robots.
Topics128,030
Posts1,055,430
Members48,422
#1558131 09/17/2024 11:21 AM
What kind of scale that is fairly accurate between 1 & 2.5 lb do you use? Where can I get one? Thanks.
Mike Barnes
1950 GMC 1-ton pickup
AD Addict & Tinkerer
I used a gun trigger pull scale. This one is similar to what I bought and used. [LINK]
Phil
Project Journals
Stovebolt Gallery Forum
Phak's is probably more accurate but I've used a small fish scale from my tackle box.
1950 Chevrolet 3100 (Ol' Roy)
Mike, Just a note that I've moved your post to the Driveline forum as that's the best place for further discussion. thumbs_up
~ Dan
1951 Chevy 3 window 3100
I use a 1/4" drive, in/lbs cheapie torque wrench. I can see how many lbs pull and see exactly when the wheel goes over center.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
7
7 Offline
That is a great idea!
59 Apache 3100
59 Apache 3100
I used this off Amazon & it worked well. Although I see other brands starting at $10 (search for "brifit fish scale")
1959 3100, original 235/3 on the tree w/overdrive. Carter YF 2100S carb, 205/75/15 w/front sway bar
