12 members (Joe H, Gray_Ghost, Woodcmiami, fonz8261, 2-Ton, cmayna, 55shaker, kades51, Forty9, NorthCoast3800, Robert Crandall, 1 invisible),
103
Mod | | | Forums66 Topics128,169 Posts1,057,037 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 10,301 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,301 | So, I have a 216 on the engine run stand. I got the ole gal running right nice. I gave the generator on just for the purpose of the fan belt to work. No wires hooked up to it and no voltage readings from the posts or from either post to ground. I believe that the generator is toast which is fine. It has good bearings to serve as an effective idler pulley for the fan belt. While the engine is running, voltage on the multimeter fluctuates from around 14 volts and 7 volts back and forth in rapid succession. With the engine off, the voltage at the battery is 12.3 volts. For further reference, it is unknown to me whether the coil which came with this engine is for 12 volts or 6 volts. I have installed a ballast resistor since I am using a 12 volt battery. I attached a jumper wire across the ballast resistor and check the voltage again, but the erratic readings continued unchanged. What the hey?
| | | | | Joined: Feb 2016 Posts: 1,994 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,994 | It sounds like whatever means you are using to charge the battery while it's running has some issue. 14 volts is pretty good for a charging system at work, 12.3 is just slightly low for a battery that is assumed to be fully charged at rest.
| | | | | Joined: Jun 2005 Posts: 1,002 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,002 |
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Mar 2010 Posts: 10,301 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,301 | If you mean regulator, I don't have a regulator on my engine run stand and there are no wires on the generator, nor any voltage coming from the generator posts when test to ground or from when testing post to post. Just to make sure, I am going to remove the brushes from the generator and start it up and see what my multimeter reads.
| | | | | Joined: Mar 2010 Posts: 10,301 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,301 | It sounds like whatever means you are using to charge the battery while it's running has some issue. 14 volts is pretty good for a charging system at work, 12.3 is just slightly low for a battery that is assumed to be fully charged at rest. I have been able to start the engine which has a 6 volt starter and it runs just fine with with 12.3 volt battery (admittedly low) and it runs very well. Currently, I have the battery charger on the battery until I am ready to test again after I remove the brushes from the seemingly already dead generator.
| | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | Try checking the generator output with an analog (needle type) meter- - - -not a digital. With no wires connected you should be getting between 1/2 and 1 volt. Most digital meters just produce unreliable gibberish when used on a DC generator. Jerry
| | | | | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | Where is the meter connected? I think it may be expected for the voltage to jump around while the points open and close if you are not connected directly across the battery terminals.
Mike Barnes 1950 GMC 1-ton pickup
| | | | | Joined: Mar 2010 Posts: 10,301 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,301 | The generator is not connected to anything. There are no wires attached to the generator.
| | | | | Joined: Mar 2010 Posts: 10,301 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,301 | I now have the engine purring like a kitten. I readjusted the valve clearance while the engine was fully warmed up. No clacking nor misses. Temperature needle is holding steady between the 8 and the 0 of the 180 on the original gauge just like every 216 and 235 that I have ever owned and driven. The oil pressure is at 14 pounds. I believe that I need to stop buying multimeters at the Dime Store. I am now moving on to the Engine Forum for specific engine questions. Come on over, it'll be fun.
| | | | | Joined: May 2015 Posts: 11,142 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,142 | I believe that I need to stop buying multimeters at the Dime Store. That.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2022 Posts: 2,483 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,483 | Carl: You told us where your voltmeter WASN'T connected, but you never told us where it WAS connected "While the engine is running, voltage on the multimeter fluctuates from around 14 volts and 7 volts back and forth in rapid succession."
(Almost) any digital voltmeter will bounce around a lot when reading varying DC voltage. My cheapy ( less than $20 ) digital meter actually has a "MAX" button, but no "MIN" button.
It also has "NCV" (non-contact voltage) setting that beeps when you get close (6 inches or so) to a hot wall socket. Doesn't tell you what the voltage is, just that it is there. The lower the voltage, the closer you have to be. It works great to tell if your electric fence is working a few miles from the fence charger. Doesn't work on DC though.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | I've got a couple of Simpson brand analog multimeters with the old school sweep needle gauge. They're a lot more stable and reliable for checking DC generator/regulator systems than any digital meter I have. Jerry
| | | | | Joined: Mar 2010 Posts: 10,301 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,301 | Mike and Bill. My bad. I misread Mikes question about where my "meter" was hooked up for where my "generator" was hooked up. For the record, while the engine was running, I used my multimeter to test voltage at the battery posts and at both sides of the ballast resistor to see what voltage drop I would have down stream of the ballast resistor. The meter jumped back and forth between 14 and 7 volts regardless of where I measured it. Hope that clears it up.
| | | | | Joined: Jan 2022 Posts: 2,483 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,483 | While the engine was running .....
The battery + to ground should stay fairly constant. Maybe vary by a few tenths of a volt as the points open and close if the battery didn't have much of a charge. I'd expect to see around 13 volts here. You should see the same on the battery side of the ballast resistor to ground.
If the meter was hooked to "both sides of the ballast resistor" I'd expect to see the voltage to jump between zero volts when the points are open and 4 to 6 volts when the points are closed. Because your meter probably updates 5 or so times a second "your mileage may vary".
If the + meter lead was hooked to the coil side of the ballast resistor (or the + side of the coil) and the - meter lead was on ground I'd expect to see the voltage to jump between zero volts when the points are open and 7 to 9 volts when the points are closed. "Your mileage may vary".
Error in the previous statement. It should read ...
If the + meter lead was hooked to the coil side of the ballast resistor (or the + side of the coil) and the - meter lead was on ground I'd expect to see the voltage to jump between 13 volts when the points are open and 7 to 9 volts when the points are closed. "Your mileage may vary".
If the + meter lead was hooked to the coil - side and the - meter lead was on ground I'd expect to see the voltage to jump between 13 volts when the points are open and 0 volts when the points are closed. "Your mileage may vary".
| | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | An analog voltmeter can also be used as a dwell meter. It will read the average of the "points open" and "points closed" voltage. With the engine running and clean points with little or no resistance, points closed voltage at the downstream (distributor) side of the coil will be virtually zero since the points are grounded. Points open voltage will be the same as battery terminal voltage, since there's no current flow. A 66% dwell reading (30 degrees on a V8 with a 45 degree cam lobe separation) will be 1/3 of battery voltage, since the points are closed 2/3 of the time. A 40 degree dwell setting on a 6 lobe distributor cam will show the same 1/3 of battery voltage reading. Simple math! Jerry
| | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | Nope it won’t A good meter reads RMS not linear average 1/3 duty cycle is 12 squared Then average that Then take the square root That’s the number you will get for a old fashion iron vane meter And the same value you will get for a modern decent meter that is true RMS
Junk meter assume a sine wave and give you all sorts of silly number But no meter will give you the linear average
Edit: 1/3 duty square wave at 12V peak will give you 6.93v on a true RMS meter It’s because RMS is about the equivalent DC required to preform the same work (or rate of energy transfer) Voltage X Current is Watts (joules / second) aka the rate of work But current is also proportional to voltage for a fixed load So averaging only the voltage is insufficient to extract the effective DC equivalent voltage value of an arbitrary waveform, it requires the Root Mean Square value to compare it to DC -s
| | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | RMS pertains to AC only. DC is straight linear.
| | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | Your method would work but I would suggest verifying the meter behavior first on a known waveform before trusting it
DC mode on some might average linearly but you would need to experiment on known waveforms beforehand as it’s not guaranteed what a meter will do with a pulse train when set to DC mode.
AC with true RMS is a guaranteed way for this method to work everytime but ya just got to calculate the expected rms first. -s | | |
