1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | I was removing the factory paint off the cab of my 48, down to bear metal to prep it for primer. I was surprised to see two numbers that must have been put on the bare metal before they painted the cab. I can clearly see "68" written on the centre of the cowl, where the body is formed to take the bell housing. Wonder what that number referred to? A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | That's probably a sequence number on an assembly line. Early Corvettes had a similar number stenciled on one of the frame rails, which just happened to be upside down due to the position of the frame during the early stages of chassis assembly. A "numbers-correct" restored 59 Vette that I inspected for a potential purchaser from France had that number in the correct position and orientation according to the original build sheet. The car had a total of 9 miles on it since a frame-off restoration job when I test drove it. The purchaser paid $90K for it, plus shipping to France! Jerry
