| | | Forums66 Topics128,052 Posts1,055,727 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | If you can manage to shoeshine polish that slightly undersize rod journal pretty close to round, I can hone a .010 or .020 undersized reconditioned Babbit rod to fit the crankshaft size. Then you can adjust the oil clearance with shims and/or scraping the bearing to fit. Jerry
| | | | | Joined: May 2015 Posts: 11,035 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,035 | I'll keep that in mind. I tried turning the 235 today and still no-go. I may have to freshen up the Evaporust I put in the cylinders. And maybe pull the head for a little more drastic action on it.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Kevin, saw my friend from ninilchik yesterday, he has an excess 216 if needed. 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Kevin, an engine that's stuck that tight is going to need to be rebored, guaranteed. Maybe even sleeved on a few holes, depending on the current bore size. Pull the cylinder head and use a big hole saw in a variable speed drill motor or a drill press to cut through the piston crowns just inside the rings- - - -about 3 3/8" or so. That will free things up so you can break the centers out of the pistons with a BFH and a block of hardwood. Then go ahead with the rebuild. Jerry
| | | | | Joined: May 2015 Posts: 11,035 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,035 | Dave, The one you gave me had some good parts I can use. That's my option if the 235 doesn't pan out. I'd sure like to try Jerry's suggestion of installing the 235 crank and rods in my block to get full oil pressure to the rods. Also, my garage is getting full of engine parts. LOL! So thanks for the offer. Jerry, I've used the BFH method on engines before by pulling the crank and driving the pistons down individually, but that's going to be a lot more work on a 235, as this one has clutch and flywheel on it with a 47-53 bellhousing on it, which I'd rather not mess up to get to the clutch bolts. I suppose another option would be cutting the fingers and disc center out of the clutch to get to the flywheel bolts. I'm not sure how well that would work. A future option in any case. It's going to be spring in any case before I get an engine back in the truck, so I have some time. No way of knowing now, but I suspect that the rod bearing that failed was set up too tight. The kid I bought the truck from said he had messed with them and I didn't recheck clearances.  Another dumb move on my part. I did that myself once on a Model A.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I have gotten clutch and flywheel bolts out of a stuck 270 with bellhousing attached, so it is possible without breaking anything.
Ed
| | | | | Joined: May 2015 Posts: 11,035 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,035 | Ed, a combination of sockets, u-joints and extensions? I'm thinking it may take a universal joint socket for the pressure plate bolts for clearance.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Kevin, a few holes made with a carbide tipped hole saw in the vicinity of the pressure plate bolts won't destroy the bellhousing- - - -it just adds a little cooling air to the clutch. Or, the holes can be filled with freeze plugs later, if you choose. I've done that on several stuck engines to get access to the flywheel bolts. About a 3/4" diameter hole or three is all that's needed, depending on how many of the pressure plate bolts are hidden. Jerry
| | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | The "fun" will be to pry all six locking plate tabs for six flywheel bolts. It's already way too much "fun" when the engine isn't stuck.
| | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | Why not remove the clutch and flywheel with the crank all in one big assembly? The transmission pulls straight off the back Then the oil pan comes off with the clutch cover And you undo all the rods and mains The crank and flywheel and clutch come out as one Then you can focus on one piston at a time What am I missing? -s | | | | | Joined: Sep 2010 Posts: 2,307 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,307 | On my spare 235 it was seized also and it soaked for two or more years with fuel oil marvel mystery oil we 40 sewing oil everything I could try you can tell the cylinders that were stuck as those ones did not leak any oil out of them I eventually got it unstuck by carefully taking as much apart as I could and after cutting the ridge off of the top of the cylinder wall used a old wooden axe handle and a hammer | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Why not remove the clutch and flywheel with the crank all in one big assembly? The transmission pulls straight off the back Then the oil pan comes off with the clutch cover And you undo all the rods and mains The crank and flywheel and clutch come out as one Then you can focus on one piston at a time What am I missing? -s You're missing having to remove the camshaft, and the timing plate, the crankshaft timing gear, etc, just to lift the front end of the crankshaft free of the main bearings. If the camshaft retainer plate bolt holes in the cam gear don't happen to be aligned with the two bolts that hold the thrust plate to the block, you'll have to break the timing gear off with a big pry bar. Then if any valve lifters happen to be rusted tight in the block, getting them lifted high enough to slip the cam out so the timing plate can be removed will be a challenge. Other than that, nothing much! Jerry
| | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | Oh yes that makes sense But if you have the timing plate cover off Do you need to remove the cam gear at all? Won’t the crank lift out with the camshaft and its gear still in the block? I’ve never done this on a frozen engine I’ve always had the benefit of being able to rotate mine I’m just curious asking here Thanks -s | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | The timing plate surrounds the crankshaft snout, behind the timing gear. It's NOT the same as the sheet metal timing cover. That plate MUST be removed, along with the camshaft, before the crank will lift straight up. I've built around 200 stovebolt engines, maybe more. Trust me on this one! Jerry
| | | | | Joined: May 2015 Posts: 11,035 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,035 | I trust what Jerry said, because I just disassembled a 216. The timing plate completely encirles the crank. I thought that I would have had to remove the crank gear, but the hole in the timing plate is big enough to remove it with the gear still in place, but it's offset a bit, so the plate has to be completely loose to remove it. THEN the crank can be lifted out.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | Oh right I forgot about that plate I wasn’t doubting it was more complicated than I thought I just couldn’t recall the detail that forces the camshaft gear removal I only took three cranks out but it’s been about ten years since the last time I did that and I did the last while the engine was in the truck and I never put that engine back together as it was a badly damaged connecting rod that scored the crank a lot on #6 piston. After seeing the crank the rest of that engine came out and all the parts are spread out on my farm now Yes it’s all making sense Thanks for the explanation -s | | |
