7 members (rfs56trk, Gray_Ghost, Wally / Montana, walter74, MRMEROTH11, David Bush, 1 invisible),
67
Mod | | | Forums66 Topics128,056 Posts1,055,803 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2024 Posts: 37 'Bolter | | 'Bolter Joined: Feb 2024 Posts: 37 | Hello; With the split panels on the rear of the cabs, is it possible to change out just the lower panel or are they not made to come apart at the belt line. I have rust through on the passenger bottom. Not sure how they are installed, so even if I weld in a patch it will still be open to the outside?
1946 GMC 1 Ton 1984 GMC 1/2 Ton 1996 Dodge 1/2 Ton 2014 Chevy 1/2 Ton 2020 Ram 1 Ton Cummins
| | | | | Joined: Sep 2009 Posts: 5,830 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,830 | FarNorth, Your question will get the best answers and help in the Paint & Body Shop forum. It's been moved there to help the conversation continue.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
