Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (ā€˜37ChevyPU, Chip O, stlcardinalsguy, 78buckshot, 1 invisible), 150 guests, and 3 robots.
Topics128,291
Posts1,058,585
Members48,492
Fox
Offline
Howdy,
Working away here and need some help.
70 c10 with a 2002 LS. I have a harness for the ls and a universal American auto wire harness for the rest of there truck. My question relates to the alternator hook up:
How do I hook this up? As you can see the LS harness has the plug with the grey wire that runs to the ECU, whereas the American auto wire has the red and brown setup. The American auto wire calls for the alternator wire to go to a plug (4A)that is in the ignition bundle. Not sure if I leave the 4A alone. Will the LS wiring take care of this? Does the ignition switch have to hooked up it? Does the ecu cover this?
Advice and thoughts on this? I might have to call the two companies later, built thought I’d pick some brains here as well.
Thanks all.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
The LS ECU will manage the alternator for you. You can leave 4A hanging (taped off or de-loomed), then just not worry about the voltage sense wire on the left connector in your picture.
Edit: The LS harness will have ignition switched power. Depending on how it is set up in the painless harness, you might be able to use 4A to feed it.
You will still need the large wire from the alternator to the battery/starter. It is likely that it should be thicker than the AAA harness provides because the LS alternators were higher current than most any of the stock older ones.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
