7 members (tclederman, RoadsScholar, DadsFirstPickup, baldeagle, MickeyP, Stovebolt48, 1 invisible), 198 guests, and 4 robots.
Topics128,108
Posts1,056,231
Members48,436
#1555690 08/18/2024 3:04 AM
My rims measure 16.5". What other rim sizes were offered on a 1965 C10?
1965 Chevy C10 Longbed Fleetside
AD Addict & Tinkerer
Rims are measured where the bead of the tire sits so if you're measuring from outside edge to outside edge and get 16.5”, it’s most likely a 15” rim.
Here is a photo of a 15” rim and it measures 16.5” outside edge to outside edge. Please note the picture make it look like I didn't have the ruler centered on the rim, but it was and it’s just an illusion.
Measuring a 15” rim.
Phil
Project Journals
Stovebolt Gallery Forum
I see. That is what I did, measured to the outside edge. So that makes sense - 15" rim. Thank you for letting me know
WarEagle1 - For a whole bunch of details on your 1965 C10, check out this original GM 1965 Chevy Truck data file. Be aware that the beginning of the file lists K10 & K20 info (applies to the 4X4 trucks) and you will need to scroll down until you find the C10 (2 wheel drive) series info to find such details. Happy reading smile
~ Dan
1951 Chevy 3 window 3100
Appreciate it Gdads51
