Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
4 members (KEVINSKI, 52Carl, Gdads51, Peggy M), 575 guests, and 1 robot.
Topics126,778
Posts1,039,258
Members48,100
Most Online2,175
Jul 21st, 2025
My question is regarding the slotted steel rail that the side glass mounts into. I have some of these that have a small hole at one end, in the center of the slot. I have others that do not have the small hole. I'm assuming that the small hole is for a small bolt or screw, in order to keep the rail from slipping off of the shaft that it travels on. So, 2 questions, Is that what the small hole is for? and if so, Why would some rails not have that hole in them? THANKS
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
Mike, do you mean on the channel where the operator roller runs? There would have to be a hole in the glass to put a screw in the part where the glass inserts. For what it's worth, there were no screws in the channel on my 1951, which would be the same as your 1953, and the window operates just fine without the operator roller coming off the end of the channel. If there were such a stop screw in the rear end of the channel, it wouldn't be possible to get the window in, as the roller has to be inserted in that end of the channel.
As far as the purpose of a hole, maybe it's for a locating pin when the channel is fabricated. Just a WAG on that.
I'll move your post to Doors where it'll be more on topic.
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.039s Queries: 14 (0.037s) Memory: 0.5932 MB (Peak: 0.6240 MB) Data Comp: Zlib Server Time: 2025-09-21 23:12:09 UTC
Valid HTML 5 and Valid CSS
