So aside from buying a different fuel pump with a diaphragm , where else can I pull vacuum from?
The fitting in the middle of the intake manifold- - - -the same place millions of stovebolts have used since the 1930s.
Now this is not being helpful at all. ,where does the VT hose run to? VT stands for Vacuum Tube. MAN stands for manifold. I have a hose ran to the manifold. Where does VT hose go please? I don`t have this fuel pump. I am guessing this pump(pic) has a diaphram to attach the VT hose.
~ BD. "You won't find me in an old folks home" Pioneer Florida Cracker 1958 Apache Stepside 1958 Apache 1/2 ton Panel 1959 Apache 1/2 ton Panel
.In short. My wiper motor with 4 ports, just needs the MAN. port to operate. Washer port is closed ,the other are open. MAN. port is stamped on the backside of it. Real small letters. Drivers side port ,to manifold.
