Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (delky, jay d, 59Kid), 133 guests, and 1 robot.
Topics128,280
Posts1,058,590
Members48,492
Hello,
Looking for a lower locking rod and instructions on how to disassemble the mechanism. Thanks, Richard
Richard J Patrick - 1946 Suburban
Richard - Try the info from the shop manual I've attached below. Removing the lock and door handle might get you going in the right direction for the rest of the door latches. Hope it helps! wink
~ Dan
1951 Chevy 3 window 3100
Hello Gdads51,
Thanks a bunch. I have that manual, however I did not state it correctly. What I need is info on the left rear door mechanism and how it can be disassembled. There is a latch lever in the middle of the door with two rods, one goes up and one down. They latch into th door frame and secure it closed, so the passenger side door can cloase on it. Also need lower locking rod.
Authorized Pest
Authorized Pest
Rpat, we have a sub-forum dedicated to DOORS. That may end up being a better place for us to put this. Check it out and see what you think.
And ... Gdads51 is on vacation for a week. He'll probably be checking in here (as he can) at the end of the day or early morning. Hopefully, someone else can help you with your questions.
~ Peggy M
1949 Chevrolet 3804
"Success comes in 'cans' ..."
