| | | Forums66 Topics128,076 Posts1,055,922 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | I have what may be original shocks and I wonder if they can be rebuilt. Why? I am in the middle of a serious restoration of a '52 3100, and would really like to run these on it.
| | | | | Joined: May 2015 Posts: 11,052 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,052 | Carl, replacement shocks can easily be disguised as originals. The tube style shocks look the same. I have never heard of tube type shocks being rebuildable. I believe they're welded together as a final assembly step. But if you don't care about ride quality just leave them bolted on. [on edit] I found this. I know that your '52 probably didn't have Bilstein shocks on it originally, but the following probably applies: Bilstein strut and shock rebuilds start at $250 per shock pending condition of damper upon inspection. If Bilstein still manufacture a kit for your car we recommend replacement with new Bilstein shocks Vs. rebuilding them.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Oct 2021 Posts: 6,772 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,772 | Hydraulic shocks can be rebuilt. Here's a guy that can do it. OEM and custom shock absorbers, USA made coil springs and leaf springs, steering dampers for all makes and models. Rebuild service for original hydraulic and lever action shocks. Rebuild service for steering gears and power steering pumps A-1 Shock Absorber Company 365 Warren Av. unit #101 and 109 Silverthorne, CO. 80498 800-344-1966 or 970-513-8283 http://www.shocks2springs.com/
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Otto, thanks for the link. Very "shocking" detailed stuff.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
