3 members (Bill Hanlon, 50Chevy3100, 1 invisible), 178 guests, and 3 robots.
Topics128,110
Posts1,056,257
Members48,437
#1555125 08/11/2024 2:45 PM
Good day, I’ve sourced and in the process of having a 1956 261 engine rebuilt to replace the 216 that went boom.
The 261 had a broken dipstick with a piece of wire to stop it from dropping down the tube!
My question is the 216 dipstick length the same as the 261? I know that there is a big difference in the dept of the oil pan between the two.
1950 Chevrolet model 1434 5-Window Canadian manufactured 1-Ton with Dump Bed / Hoist
You will never stop learning new things, no matter how old you are.
1 Offline
Assuming you have a dipstick tube in the block, I'd just make a dipstick out of a piece of rod. Fill the pan with the specified amount of oil and mark the rod with a file, after brazing or welding a washer to keep it just off the pan bottom so it doesn't wear a hole in the pan.
I know if you over fill them they will blow oil out the breather and make a mess. It might be worthwhile to make a windage tray or extend the factory baffle to keep the crank wind from stirring up the oil, though the factory never saw the need so far as I know. Maybe the later 261 pans had such a tray. The pan I have is a 56 according to its yellow color and has the floating oil pickup rather than the fixed one screwed to the main cap.
1951 3800 1-ton
In the DITY Gallery
O Online: Content
There is a link on this site somewhere to a chart that lists all the lengths of the dipstick tubes for various engines and years. Of course this presumes you have the correct length dipstick tube installed on your engine.
1950 Chevrolet 3100 (Ol' Roy)
AD Addict & Tinkerer
This may be the chart Otto is refering to.
Phil
Project Journals
Stovebolt Gallery Forum
O Online: Content
It be.
doyle1950, The 216 and 1956 261 do not share the same dipstick. To get down into the detail level for the dipstick on your 1956 261, it should have the dimensions listed in the snipped pic below taken from the other post screen capture. Hope this helps define what you need. smile
~ Dan
1951 Chevy 3 window 3100
Thanks for all the suggestions, once I get the engine block back I’ll measure up the volume in the pan and fab up a dipstick.
