| | | Forums66 Topics128,094 Posts1,056,048 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | Will a flywheel with the numbers F292, GM8, 3978456N fit a 1957 235 six?
Rick
1939 Chevrolet Stake Truck
| | | | | Joined: Jul 2000 Posts: 2,192 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,192 | Are you sure about the numbers? Flywheel
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Jan 2022 Posts: 2,450 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,450 | Googling 3978456N returns a bunch of different Chevy V8 engines that use this flywheel. 11" clutch disk. 14" flywheel. 168 tooth, typical for a 12v system. F 29 2 is a date code for June 29 of some year that ends in a 2, like 1952, 1962, 1972, etc. Not saying it wouldn't bolt to your '57 235, but it certainly wasn't born there.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Having done several 235 to V-8 conversions, there is virtually nothing in common between the engine types. If it is a V-8 flywheel, it will not work. Fred
| | | | | Joined: Sep 2011 Posts: 1,453 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,453 | Are there 3 dowell pins at the rear flange of the crank?
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | |
