5 members (Steelonsteel, 2-Ton, Cosmo, 32Fordpuchoptop, farmallb), 150 guests, and 2 robots.
Topics128,089
Posts1,055,991
Members48,430
#1553605 07/25/2024 2:17 PM
Will a flywheel with the numbers F292, GM8, 3978456N fit a 1957 235 six?
Rick
1939 Chevrolet Stake Truck
Insomniac
Insomniac
Are you sure about the numbers?
Flywheel
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Googling 3978456N returns a bunch of different Chevy V8 engines that use this flywheel. 11" clutch disk. 14" flywheel. 168 tooth, typical for a 12v system. F 29 2 is a date code for June 29 of some year that ends in a 2, like 1952, 1962, 1972, etc. Not saying it wouldn't bolt to your '57 235, but it certainly wasn't born there.
Having done several 235 to V-8 conversions, there is virtually nothing in common between the engine types.
If it is a V-8 flywheel, it will not work.
Fred
Are there 3 dowell pins at the rear flange of the crank?
BC
1960 C60 pasture art
