| | | Forums66 Topics128,049 Posts1,055,695 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Have access to a 5.7 Chevy V8 set up for marine operations. I’m not familiar enough with these to know exactly what changes need to be made for use in a 1984 Chevy 1/2 ton. Engine still has all the marine stuff on it but has been removed from the boat and of course separated from the outdrive. Exactly what needs to be removed/changed/purchased to be of use to me? Thanks
| | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Exhaust manifolds, for sure. Marine engines use exhausts with built in water jackets. On twin engine boats, one engine usually runs backwards, like the Allison V12s on a P-38 fighter plane. The torque reaction on the props cancel each other out to prevent the boat from trying to run in circles. Reverse rotation engines have an oddball gear drive for the camshaft, and a rear oil seal that must be swapped out. Most marine engines will have a lot more "full throttle" hours than street engines, so they're usually built with racing engine bearing and piston clearances- - - -a little looser than a land-based engine. Jerry
| | | | | Joined: May 2015 Posts: 11,031 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,031 | The torque reaction on the props cancel each other out to prevent the boat from trying to run in circles. A friend has a boat with two outboards. We were on a trip in it when the reverse rotation lower unit crapped out. He was unable to get a replacement reverse rotation lower unit, so put a standard rotation unit on it. Next time he took it out, he found he had gained 5 MPH in top speed, about a 10% increase. All the boat people said "That can't happen" but it did. He has no issues with the boat trying to run in circles.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | It depends on the size of the props, and how much torque they can exert on the stern- - - -the bigger the prop, the more side thrust there will be. Container ships with huge single screws have to run computerized steering correction to run in a straight line. Jerry
| | | | | Joined: Feb 2016 Posts: 1,984 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,984 | I would also guess that the water pump and maybe the intake manifold would be different than a truck engine, I can't remember if they ran a Q-jet on the marine engine, I don't think they did. The throttle linkage is totally different from truck to marine but that should be simple if you go with a Q-Jet. Probably need some front accessory drive pulleys and brackets, there will be no fan on the marine. All of those parts are a dime-a-dozen. You could probably find another 350 at a yard and use all of the exterior parts as needed. If you look for one from roughly the same vintage as your truck, the brackets should put you in business.
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | HRL, this is from a single single engine boat, so no counter rotation issues. Thanks
78buckshot, engine is carbed but I haven’t seen it so not sure what carburetor it has. Water pump, brackets and pulleys it is. Thanks
| | | | | Joined: Nov 1995 Posts: 5,716 62401 | | 62401 Joined: Nov 1995 Posts: 5,716 | Martin -- was that engine run in fresh water or salt water? Considering your location, I'll guess fresh. If salt water ....
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | John, it is indeed a fresh water engine. Don’t know the hours as the boat was cut up and scrapped a couple of years ago. It will cost nothing to get it but I’m thinking it will need a bit of refreshing. Trying to work up a budget to get it at least running. Thanks all!
| | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Martin, one thing I'vwe observed on the fresh water run marine engines I've rebuilt- - - -I don't think I've ever seen one with enough cylinder wear to need to be rebored. A good friend who has spent most of his mechanical career around houseboats and other large water craft like cabin cruisers has expressed the same opinion, and he claims that's because a propeller doesn't put as much torque load on the crankshaft as a mechanical drivetrain does. On the other hand, a boat is running "uphill" all the time- - - -trying to climb out of the hole it's in! Jerry
| | | | | Joined: Mar 2021 Posts: 430 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 430 | Remember the marine engines use a electronic thermostat on the cooling since there is no recirculation since its pulling water from outside and no radiator closed loop system. its a easy swap to automotive type as you are replumbing all the hoses anyway. | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | On the big rigs they run heat exchangers. The main cooling system runs a thermostat and regular antifreeze, which is circulated through a water-to-water heat exchanger that circulates outside water around a copper core containing the coolant. That also prevents salt water from getting to the engine(s) on offshore rigs. The heat exchanger has its own water pump for circulation. Jerry
| | | | | Joined: Nov 1995 Posts: 5,716 62401 | | 62401 Joined: Nov 1995 Posts: 5,716 | Another difference is that most marine engines, at least the ones I've run, operate at a constant rpm most of the time. Unlike land engines that are over the rpm band.
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Feb 2016 Posts: 1,984 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,984 | Another difference is that most marine engines, at least the ones I've run, operate at a constant rpm most of the time. Unlike land engines that are over the rpm band. If the op has the time and money, checking the compression ratio and choosing a camshaft for his intended purpose may be in order, I'm just guessing that a marine cam may be different than a truck cam due to the more constant RPM of the marine engine.
| | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Most of the marine engines I've worked with have a cam similar to what would be used in a medium-duty truck- - - -with more emphasis on torque and smooth idle than maximum horsepower. That seems to be pretty useful for a pickup as well. Fairly short duration, with a quick lift rate to get the valves open quickly and hold them open for as long as possible to allow the engine to breathe well at low to midrange RPM, without the choppy idle associated with high HP- - - -high speed cams. That's also where a "street roller" cam shines- - - -slap the valve fully open quicker than a flat tappet cam can, and hold it there as long as possible before closing quickly. Jerry
| | | | | Joined: Feb 2016 Posts: 1,984 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,984 | He should be good to go then if it has been maintained.
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | We picked up the engine last night and had a very pleasant surprise. The engine had been abandoned by the previous owner in a garage belonging to my son’s wife’s aunt. He had only seen the engine in the dark by flashlight. Turns out this engine is a brand new 5.7 crate motor fully rigged for marine use. Zero hours, new oil, paint not even worn off the belt pulleys. Scoped the cylinders and absolutely no wear, no deposits on the valves and new plugs. Numbers were run by both the local PD and the County Sheriff and came back clean. The property owner paid us to remove it as part of the property cleanup. 14 year old grandson now has a “new” engine for his 1984 Silverado that he and Dad (Terry B) are building. Happy campers all around.
| | | | | Joined: Feb 2019 Posts: 4,475 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,475 | Wow, What a score! Congrats to your son and grandson!
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Sep 2013 Posts: 1,361 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,361 | Martin, that is an amazing find! Now the bar has been raised...gotta build the rest of the truck to the new engine standard.  Said the man who has absolutely no skin is this game. Best of luck to all. RonR
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: Jan 2014 Posts: 3,677 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,677 | Recently watched a YouTube video where some builders were prepping and installing a marine 454 into a vintage car. The engine was far from new, but the cleanliness and condition of the internals would make one think it was brand new.
Their theory was that marine engines eat zero dirt, at least by comparison to road vehicle engines. Jerry’s comments about the different torque load also makes some sense.
1951 3100
| | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | What a luck find. Must be all that clean livin'. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | |
