0 members (),
361
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2024 Posts: 22 'Bolter | | 'Bolter Joined: Apr 2024 Posts: 22 | Can someone tell me if there is an inner fender to firewall bracket for the passenger side similar to the drivers side? The driver side incorporates the emergency brake bracket. I acquired a basket case project and am uncertain if the passenger side inner fender mounts directly to the firewall of if I am missing a bracket Thank you, Dennis
| | | | | Joined: Nov 2021 Posts: 1,403 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,403 | Watching this thread as I have the same question. My passenger side inner fender location seems to indicate one would be there. | | | | | Joined: May 2015 Posts: 11,152 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,152 | The passenger side inner fender bolts directly to the toe board (at least it does on my 1951.) No bracket like on the driver's side. The right fender skirt has weld nuts (some of mine needed to be replaced, and bolts from inside the cab into them directly thru the toe board. The FAM (which covers only 1954 models for front clip sheet metal) Section 11, Sheet 10.00 shows it in the upper left corner of the page.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Apr 2024 Posts: 22 'Bolter | | 'Bolter Joined: Apr 2024 Posts: 22 | | | |
