2 members (Nick in Manitou, 1 invisible), 350 guests, and 5 robots.
Topics128,162
Posts1,057,042
Members48,460
Can someone tell me if there is an inner fender to firewall bracket for the passenger side similar to the drivers side? The driver side incorporates the emergency brake bracket. I acquired a basket case project and am uncertain if the passenger side inner fender mounts directly to the firewall of if I am missing a bracket
Thank you,
Dennis
Watching this thread as I have the same question. My passenger side inner fender location seems to indicate one would be there.
1949/50 3600 Project
Follow in Project Journals
The passenger side inner fender bolts directly to the toe board (at least it does on my 1951.) No bracket like on the driver's side. The right fender skirt has weld nuts (some of mine needed to be replaced, and bolts from inside the cab into them directly thru the toe board. The FAM (which covers only 1954 models for front clip sheet metal) Section 11, Sheet 10.00 shows it in the upper left corner of the page.
Thank you very much !!
