4 members (Otto Skorzeny, Rexville48, Gdads51, 59 fleet), 133 guests, and 2 robots.
Topics128,070
Posts1,055,896
Members48,428
#1552595 07/13/2024 7:58 PM
I am looking to replace a 292 with another engine I found online, but I can't be sure what I am looking at.
The engine has a block casting of 392 969 GM 56 or 58. The engine mounts don't look offset like the 292 I have, but the rest of the engine, from manifolds to oil filter, fuel pump to pushrod cover, is similar to my 292.
Mostly I am just looking to see if this can be bolted in place of the 292, with maybe some mount modifications. Does anyone know how to read the casting numbers?
Moderator, Electrical Bay
What do the mounts look like? An image would be good.
~ Jon
The pictures aren't very definitive, but it does show most of the engine.
That's a 230 or a 250- - - -they run the same block casting number. A 250 has a longer stroke crankshaft. A 292 has a much taller pushrod cover and the oil pan to cylinder head measurement is taller. It will bolt to the same bellhousing as the 292, but you'll have to modify the engine mount position on the passenger's side. Throttle linkage, and probably the exhaust system will have to be modified to complete the swap. Put a borescope into a spark plug hole and look at the top of a piston. A 230 engine has flat tops and a 250 has about a 1/4" deep recess in the piston crown. You'll be seriously disappointed in the power loss, compared to a 292.
Casey - That appears to be a 230 or 250. Very similar to your 292, but as noted it has the non-offset motor mount points. When I zoom in on the pic showing the casting numbers, I think it actually should be 3821968 3921968.*
That block casting number in my resource info was used for 1967-70 230’s and 1967-79 250’s. There should be a casting date code on the same side of the block back by the starter area that can help towards figuring out which one. There should also be an alpha-numeric serial number stamped in the machined pad just to the rear of the distributor mount area. That will really help in confirming what it is.
Give us a bit more info to help you ID this engine.
Jerry beat me to push button - lol!
* Corrected mistyped casting number. Thanks for seeing that klhansen! smile
Last edited by Gdads51; 07/14/2024 1:59 PM. Reason: correct mistyped casting number
~ Dan
1951 Chevy 3 window 3100
This Has 3921968 as a 64-76 Chevy/Olds 230-250.
I'm pretty sure digit #2 is a 9 (not an 8 as Dan suggested), can't see a 1 in the #4 position (but I'll take Dan's word for it), and pretty confident that the last 3 digits are 968.
Well nuts, I was hoping it was a 292...
Sadly, my engine is in such dire straits, I probably will still see a rise in power. Is the 230/250 that big a loss, should I just try for a 350? This is mostly a patch job, i just need the truck to reliably operate in the short term, I plan to put a bigger engine off in the semi distant future.
I have installed a 350 in place of a 292. It's a real PITA, as the motor mount on the passenger's side must also be relocated to the same position as the one on a 250. Throttle linkage and exhaust will not fit.
I should keep a 292 in it then, if I can. Problem is all I can find right now are over a state away. I am ambitious, but not that ambitious.
O Online: Content
There's a company that specializes in shipping engines and transmissions from anywhere, to anywhere.
I had a Cadillac Engine shipped from Detroit to Atlanta for $200
www.engineshipping.com
1950 Chevrolet 3100 (Ol' Roy)
I drove nearly a thousand miles a couple of months ago, and six engines and a big radial drill press followed me home. I'm headed for Texas soon to pick up a 20 foot storage container with several engines and a bunch of other parts in it.
Kevin thanks for catching that "9" thing in the casting number. Had a case of stubby-fingeritis - whoops. dang My resource book did say "3921968", I just mistyped it. I corrected my original reply above.
~ Dan
