0 members (), 132 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#1551644 07/05/2024 4:17 PM
8
nothing beats a try but a failure
8 Offline
While the truck is under reconstruction I would like to remove the temperature sensor and plug the hole in the head. I tried several pipe threads. None fit. No bolt will fit. What plug size am I looking for?:
1955.1 3600 5 window 4 speed all original except the 410 gears.
In the Project Journal
Easiest way would be to use a rubber stopper.
Did you use a thread pitch gauge on the fitting?
I’m thinking it should be a standard bolt diameter and pitch (coarse or fine.)
I did some checking in your Project Journal. Is the head in question the "8385913" one you have posted pics of previously? If so it should have the smaller temp sensor port which is 3/8" NPT (National Pipe Thread). A brass one from a FLAPS should fill the need. Others will chime in and confirm or correct my info.
~ Dan
1951 Chevy 3 window 3100
8
8 Offline
You know I to thought it was 3/8ā€. I questioned my 3/8ā€ brass fitting after dry fitting it. The reason was it screwed in 1 1/2 threads by hand then it stopped. If memory serves me right pipe fittings are tappered. So I applied my go to threads sealant Permatex 300 and tightened with an open end wrench.
H Online: Content
That one's a straight bolt thread, not a tapered pipe thread. I believe it's a 5/8" coarse thread. I've seen people plug the hole by putting a copper penny into it and installing a shortened Allen bolt on top of it. You might have to file or grind the OD of the penny a little to make it drop into the hole.
