2 members (IHPWR, whateverpratt), 152 guests, and 1 robot.
Topics128,157
Posts1,056,878
Members48,458
#1551506 07/04/2024 2:37 PM
Truck has been sitting a good while, It will not go into gear unless engine is off. Throwout arm moves in and out. I'm thinking
pressure plate /clutch is stuck or frozen, I'm thinking of maybe dragging in 2nd or 3rd gear and see if it breaks loose, Your thoughts
and or ideas??? TIA
Dan
Dan,
I haven't had to deal with a stuck clutch disc myself, but below are 3 different previous threads that offer solutions to your problem. Give them a read and a try and see if you can get it broke loose. One of them is bound to work. smile
Clutch Disc stuck by Mr. Giant
Stuck Clutch on 46 1.5ton by Lend-Lease 1.5
Transmission help please by Stroehlman
~ Dan
1951 Chevy 3 window 3100
Thanks for the prompt reply!!!! Will start trying this evening/weekend and let you know the results
Dan
