| | | Forums66 Topics128,162 Posts1,056,913 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Truck has been sitting a good while, It will not go into gear unless engine is off. Throwout arm moves in and out. I'm thinking pressure plate /clutch is stuck or frozen, I'm thinking of maybe dragging in 2nd or 3rd gear and see if it breaks loose, Your thoughts and or ideas??? TIA
Dan | | | | | Joined: Sep 2009 Posts: 5,980 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,980 | Dan, I haven't had to deal with a stuck clutch disc myself, but below are 3 different previous threads that offer solutions to your problem. Give them a read and a try and see if you can get it broke loose. One of them is bound to work. Clutch Disc stuck by Mr. GiantStuck Clutch on 46 1.5ton by Lend-Lease 1.5Transmission help please by Stroehlman
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Thanks for the prompt reply!!!! Will start trying this evening/weekend and let you know the results
Dan | | |
