1 members (delky),
65
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2018 Posts: 759 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 759 | I"m working on the doors for my 53 project truck. They are mostly covered in surface rust, but are otherwise in fairly decent condition. I'm curious. If I take a stiff wire wheel to them, knocking off the worst of the rust, then sand them smooth, will that be clean enough for epoxy to adhere well. I"ll say that they will be 95% rust free bare metal at that point. There's a small number of spots that have small pits. Those will still have a little rust in them. In the past, I've normally sand blasted sheet metal prior to applying epoxy. But this time, I don't really want to sandblast the doors.
Mike Burns 1940 Chev 1/2 ton 1953 Chev 1/2 ton 1950 Studebaker Starlight Coupe 1947 Indian Chief 1943 Indian 741
| | | | | Joined: Feb 2016 Posts: 1,984 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,984 | I would sand with 80 grit down to 220-320 grit, then use Metal- Prep to clean and etch, then water wash, when totally dry shoot the epoxy.
| | | | | Joined: May 2015 Posts: 11,036 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,036 | If Metal-Prep is phosphoric acid based, be sure that the epoxy used is tolerant of that. Even washing down with water may not get rid of all the iron phosphate, which most epoxy doesn't go well with. I don't think you'd need to go as file as 220 or 320 grit with your sandpaper. Generally rougher is better for paint adherence.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2016 Posts: 1,984 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,984 | The Metal - Prep that I have used leaves a zinc phosphate surface, I have only used one type from the auto paint supply, possibly other sources have a different chemical make-up.
| | | | | Joined: Apr 2017 Posts: 230 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 230 | Epoxy primer is designed to adhere to properly sanded …. Scratched bare metal. Sometimes you can use an acid based primer to etch the metal but sanding is best. If you have something between the metal and the epoxy, it won’t adhere properly and anything you put on top will have problems. All of your money products are on top of the primer so if the primer fails to adhere, you loose a lot…. And it looks bad. You can use phosphoric acid to get to the hard to reach spots then sandblast but you run the risk if leaving the residue ….. just where you don’t want it. Mechanical metal preparation by sanding, sandblasting is the best way.
Mike
1940 Chevy 1/2 Ton presently... Almost done 1940 Chevy Business Coupe... In pieces
