7 members (Shaffer's1950, Hotrod Lincoln, Uncles51, Lostbuthaulinass, Slick Willy, Woogeroo, homer52),
88
Mod | | | Forums66 Topics128,134 Posts1,056,410 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2019 Posts: 10 'Bolter | | 'Bolter Joined: Jun 2019 Posts: 10 | Hello, I have a 228 GMC motor that is stuck. How do I get the clutch and bell housing out. Engine is out of truck in shop. | | | | | Joined: Feb 2004 Posts: 29,815 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,815 | Use a small carbide tipped hole saw to bore holes in the bell housing so you can reach the pressure plate bolts that are hidden by the bellhousing with a universal joint socket. 3/4" or slightly larger should work. Then you can plug the holes later if you wish. Even if they're not plugged, the holes don't keep the bellhousing from functioning properly- - - -they just add a little ventilation to keep the clutch cool. Jerry
| | | | | Joined: Dec 2020 Posts: 1,966 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 1,966 | Jerry , thats genius.
Last edited by Peggy M; 06/26/2024 1:33 AM. Reason: Remove quote - not necessary ;)
~ BD. "You won't find me in an old folks home" Pioneer Florida Cracker 1958 Apache Stepside 1958 Apache 1/2 ton Panel 1959 Apache 1/2 ton Panel
| | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | If the engine is out of vehicle I’m not 100% sure, maybe something won’t allow these steps in this case But Could you disassemble as follows? Remove oil pan and timing cover Remove all rod and main bearing caps Remove crank with flywheel assembly as one Now the bell housing can be removed from block and piston and rods individually removed as needed Let us know Thanks -s | | | | | Joined: Jun 2019 Posts: 10 'Bolter | | 'Bolter Joined: Jun 2019 Posts: 10 | Thanks everyone for the tips. Engine is not on my stand so I might just try the tip of drilling it. Much appreciated. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I took a siezed 270 crank out reaching through retainer hole in bellhousing with .5” socket set U-joints.
Ed
