0 members (),
170
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | Can or should I use the white plumbers Teflon tape on my threaded gas line connections? | | | | | Joined: Oct 2021 Posts: 6,791 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,791 | Not necessary if your fittings are new or undamaged. If you must use something due to bunged threads or something, use Permatex Seal Lock. It is a combination of blue thread lock and thread sealer. https://www.amazon.com/Permatex-57535-Seal-Thread-Compound/dp/B0787N1LTY/ref=asc_df_B0787N1LTY/
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Jan 2000 Posts: 734 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 734 | I've started using a drop of oil on fuel line brass threads because I can never get them tight enough dry. Have also used teflon tape many times and never had a problem. It helps if you're nitpicky about cleaning every tiny sliver out of the threads with a dental pick or something every time they're disconnected because they can mess with your carb if you don't.
Matthew 6:33 1952 Chevy 1/2-ton 3100 Late '55 235/SM420/torque tube 3.55 Dalton Highway survivor (using original 216) www.truckwithaheart.com | | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | Thanks. New brass fittings. The oil trick makes since. Brass fittings always seemt to want to drag and bind when tightening. I know the teflon tape in addtion to filling the voids acts a a lubricant on the threads.
| | | | | Joined: Feb 2016 Posts: 1,989 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,989 | Depending on what fitting you are referring to, a flare fitting, inverted flare fitting, compression fitting, or a fitting that relies on an O-ring needs no sealer on the threads because the threads are not the sealing surface. Pipe threads typically call for sealer, brass to brass or brass to steel may not need sealer due to the soft nature of the brass allowing the threads to conform to each other.
| | | | | Joined: Mar 2014 Posts: 4,489 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,489 | I've noticed today's brass fittings don't seem the same as the ones of past years. I've been told to avoid teflon tape. Threads (small thread-like pieces) of it can come off and go into your carburetor where they can mess with your needle/seat, main jet, metering rod to jet, etc.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Jun 2022 Posts: 557 'Bolter | | 'Bolter Joined: Jun 2022 Posts: 557 | I use a small amount of regular old redneck pipe dope. Seals just fine without having to over tighten the junk-metal threads on the carb body. On ferrule or flare fittings I tighten and then crack it open and retighten a couple of times. Works for me.
~~ Jethro 1954 3100Back to LifeIn the Dity Gallery1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020 | | | | | Joined: Jul 2000 Posts: 2,193 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,193 | Maybe this old thread will help. The stuff I used is still good. Gas Leak
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Oct 2021 Posts: 6,791 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,791 | I would assume that the fittings attached by the factory - say, Inline Tube - would be the NPTF for fuel that don't require sealer. Same with fuel pumps, gas tanks, etc.
I have a new tank, steel lines from Inline Tube, and the rubber transition from tank to steel line that cam with the fittings attached. I did not use any sealer on any of these connections and I have no leaks.
| | | | | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | Teflon tape is for- - - - -plumbers! A drop or two of Permatex Super 300 on a tapered pipe thread fuel fitting might be OK, as long as you don't put it within a few threads of the end of the fitting. Flare fittings don't need ANY sealer- - - - -the threads have nothing at all to do with sealing- - - -they just hold things together. Jerry
