We are putting new glass in our 51 gmc 100 truck. I made the mistake of ordering a kit for the window felts and all those other pieces. They don't fit right at all. I've tried classic part and old chevy. My problem is the names of the pieces and where they go. Anyone have a good diagram and piece names?
Otto, He has a '51 that has vent windows. LMC doesn't even show vent windows.
Try the Filling Station. They also have a good video on restoring the vent windows. You'll need felt channel that fits on the top and rear portion, and another narrower felt channel that goes in the division bar and supports the front of the main window. I think the video has their part number information.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
Did you mean LMC or The Filling Station? I''ve had good luck with stuff from the latter. Used their parts for vent window rebuild and door run channel. Although the parking brake cable boots and tie rod end boots i got from them weren't up to snuff.
I got my parts to restore my vent windows from Classic Parts and they were good. I bought their parking brake boots, and they were not good. I also bought boots from Chevs of the Forty’s and they look exactly the same.
Phil Moderator, The Engine Shop, Interiors and Project Journals
1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc Brakes Project Journals Stovebolt Gallery Forum
I finally checked out their stuff. The felt kit is on back order. The door weather rubber kits are spendy compared to the crappy ones I bought at LMC. I know if I want quality, I'm going to have to put up some good cash. Hubby just got himself a new project. It's not going to take him long. It's a short fix up. He went from a chevy 1500 HD gas to a Ford f350 turbo diesel. Better for his towing. After he gets his few things done on it, we should be getting back to the better truck. 🤣🤣🤣
