6 members (GIJOE298, TexasJim50, David Bush, Otto Skorzeny, Peggy M, 1955 1 Series), 82 guests, and 1 robot.
Topics128,154
Posts1,056,851
Members48,456
Are there two different sizes (length) of clutch throw-out bearings used on the 1947-1955 1st series trucks? Wondering if I missed something. Thanks
1950 Chevy 3100 truck
1950 Chevy 3100 PU all stock
Curtis Lee, Your question will get better answers in the Driveline forum, so it’s been moved there for further help and conversation. wink
~ Dan
1951 Chevy 3 window 3100
Moderator, Electrical Bay
There were a couple of different lengths depending on which pressure plate & clutch plate combination your truck used. You can tell which one you need by measuring your original to bearing.
~ Jon
These are the most common versions. If the pressure plate has FLAT FINGERS then it would use the taller of the two pictured. The shorter version is designed for pressure plates with fingers that tilt away from the flywheel.
Which one / typ is the best solution? I´ve got the short throw out bearing version...arround 2600km and it becomes noisy so I have to change it. I´am still on the project this week and orderd the " long throw-out bearing with the flat fingered pressure plate.
(292cui I6 engine with SM420)
1947 Chevrolet 3800 1-ton long bed
292 cui, GM 14 bolt rear-end, 4 x disc brakes
In Frankfurt, Germany
Pictures in the Forum Gallery
Hello Sven,
Neither is better than the other. It all depends on how much space is between your pressure plate and your clutch fork. Some pressure plates are designed differently and because of that they will be thinner. Those will usually need the longer throw-out bearing. I hope this helps.
~ Jon
Thank you Jon for your statement.
I will see this the next days. Receive the new cluctch kit yesterday. I ordered this part because it was named " Heavy Duty" (Rockauto Part MU54731B/ Perfection Clutch). If anyone is interested I can take some pictures of both completed versions
What I´am interested is from which year they used clutch fork with / without leaf spring clip.
Just to complete the versions of throw out bearings:
>> there are fixed and self-aligning parts
Sven, I can not remember which of the forks used no clips. Sorry. Mine is a 1952 and it used a clip.
~ Jon
Just to complete the topic because I worked on it last week, here is the combination of throw out bearings with clutch pressure plates.
For me the flat pressure plate with higher throw out bearing will be the best solution because of a better clutch pedal feeling during driving the truck.
Thanks for letting us know, Sven.
~ Jon
Riding in the Passing Lane
A lot depends on what engine you have. The flat fingers with the long TO brg is not good for high RPM. It was usually listed for 6 cyl. engines. The extended fingers came out with the V-8 engines.
George
1972 Chevy c10 Cheyenne Super
