0 members (),
68
8
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2021 Posts: 42 'Bolter | | 'Bolter Joined: May 2021 Posts: 42 | I need the fuse sizes for my 12-volt heater motor, 12-volt wiper motor and the Flasher unit to the lights. I'm replacing the little tube fuses with a new fuse box Couldn't read one fuse and another wasn't in the holder. Took photo to help see better, been sittin' on the internet looking. And I've seen the info before, but where? Aggravating to say the least Thanks
1950 Chevy 3100 PU all stock
| | | | | Joined: Mar 2021 Posts: 430 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 430 | year make and model will help
assuming 1950 Chevy 3100 PU all stock based on your tag line
But your new fuse box should have fuses already that are for 12v and sized for those ports if you went with a wiring harness fuse box.
| | | | | Joined: May 2021 Posts: 42 'Bolter | | 'Bolter Joined: May 2021 Posts: 42 | Sorry I ask and sorry I didn't fill out the form. Thanks
