0 members (), 94 guests, and 4 robots.
Topics128,271
Posts1,058,313
Members48,485
#1548892 06/06/2024 4:18 PM
good day bolters- changing out gen to alternator- bypassing the ammeter for now- With the DA plug on the alternator it states taking the exciter wire to the coil or switch.
the ignition switch power is from the ammeter. elimination of the battery feed to ammeter. should i run a wire to the head/tail/park/dome/park/stop switch from battery ?
as far as the exciter wire, should i run to coil or switch? thanks for your help, Lynn
1953 1/2 ton w/216
Family truck 1953 1/2 ton w/216
Authorized Pest
Authorized Pest
Weewilly, moving your post to the Electrical Bay for answers.
~ Peggy M
1949 Chevrolet 3804
"Success comes in 'cans' ..."
thank you- sorry
Can you describe in sentences what your question(s?) are?
I can't really understand what you are trying to ask.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Maybe this will help:
https://www.chevytalk.org/fusionbb/showtopic.php?tid/139844/
Starts at step 21:
21. Remove the F wire from the generator and fold it back onto the wiring harness
22. Remove the F wire from the voltage regulator and fold it back onto the wiring harness
23. Connect the 2 wires left on the voltage regulator to each other using a nut and bolt and make sure they are insulated with electrical tape. You can splice them together, but then it will be harder to return it to original.
24. Remove the voltage regulator from the firewall
25. Remove the Generator and the lower generator bracket from the motor (my kit came with a new upper alternator bracket that was superfluous.)
26. Plug the DA connector into the alternator.
27. Disconnect the wire from the A post on the generator and connect it to the BAT post on the alternator along with the red DA plug wire.
28. Run the white or yellow DA plug back through the firewall to the ignition switch and hook it up to the IGN post.
29. Use black electrical tape to wrap the harness where the ugly white or yellow wire runs through the firewall and cover up the F wire from the generator
30. Connect the battery and you are done.
don
