1 members (UtahYork),
80
Mod | | | Forums66 Topics128,049 Posts1,055,637 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 48 | I have a set of signals that I'm putting on my 3 ton. There are 5 wires in the switch. The middle one is the "hot" one but what ones do I use for the rears. Can I hook the parking lights to the other wires for front and rear? BTW, I have molds made and can make the amber and red arrows for anyone that needs them. They look great.
Matt | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Matt, I have enclosed a link to a pretty good page of Signal-Stat diagrams. Maybe one will apply to the switch you have. I'm not sure what you consider a parking light, but the only wires involved with turn signals would be brake activated lights for the rear and "turn signal" lights on the front...would the fronts be considered parking lights? http://www.film.queensu.ca/CJ3B/Tech/SignalWiring.html Stuart | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | I have to know what model Signal Stat. On models 900,901 and 910 Red = Right Front Green = Left front Black =Right rear Grey = Left rear Blue = Pilot light Black/grey = stop light switch Yellow = Flasher load (L) For models 902,903 & 905, it is slightly different
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Thanks Automarc,A picture is worth 1000 words.
| | | | | Joined: May 2006 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 48 | I have the model 700, very close to the 800 only the wires are all cloth covered in white, and I have 5 wires not the 8 shown. I know the middle one goes to the fuse and ammeter. I have a 12 volt system. She is a 47.1 3 ton truck. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | naddaclue,
Cletis has a Tech-Tip on this very unit right here on the site...check it out!
Stuart | | | | | Joined: May 2006 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 48 | Got it....thanks....forgot to check there, now I have to figure out what is front and what is back. | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Headlights are in front,tail lights are in the back.
Sorry,I couldn't help it.... lol
| | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | gtow69,,,when did they change it??? I didnt get a memo on that!!! And my people didnt get a call from your people. JEES!! | | | | | Joined: May 2006 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 48 | hhhhhhhhhhmmmmmmmmmmmm, I never looked at it that way....well if my headlights start blinking red then I know it's hooked up wrong. If you get a chance....fax a copy of that memo...or have your people call mine....
Lol | | |
