5 members (Wayne67vert, Gray_Ghost, tclederman, Ridgeback, 1 invisible), 56 guests, and 5 robots.
Topics128,021
Posts1,055,372
Members48,420
#1548292 05/30/2024 8:36 PM
This piece was mounted below the Carter carburetor on a 216 engine. Can anyone tell me what it is and who made it? Never saw one before. Stock or aftermarket? Thanks!
O Online: Content
It looks like a carburetor base that someone used as a spacer.
1950 Chevrolet 3100 (Ol' Roy)
It's a throttle speed governor. Normally found on industrial engines and larger trucks. It appears that the throttle plate
was removed to render it inoperable.
Fred
It is a "Governor" as Fred said. It's used normally on Big Bolt engines to control engine over-speed conditions. The side plate (flat semi-oval plate attached with screws) under your finger tips probably is stamped CHEVOLET VARI-SPEED. See the attached pic below. There are probably other makes/manufacturers, but that's the one I am familiar with.
~ Dan
1951 Chevy 3 window 3100
7
7 Offline
WOW, that brings back a flood of memories. I grew up in the 50's-70's 2 blocks from King-Seely in Ann Arbor. The building is now condos but it has a long history.
Yes sir, you are correct. Did some work with the wire brush, and was able to make out the markings. Just like you said, Chevrolet Vari speed. Thank you for the reply! I learned something new.
Carburetion specialist
As others have mentioned, the item is a governor; more specifically, a "sandwich" governor, as it is sandwiched between the carburetor and the intake manifold. Other manufacturers of sandwich governors of which I am vaguely aware are Handy, Hough, and King-Seeley.
All of the major carburetor companies (Carter, Holley, Rochester, Stromberg, and Zenith) also had carburetor models with integral governors; that is, the governor was part of the carburetor.
Governors were activated by a variety of controls. Holley used on various models, water pressure and oil pressure. Stromberg used oil pressure. Carter, Rochester and Zenith used vacuum. There are probably others.
Jon
The Carburetor Shop
