| | | Forums66 Topics128,257 Posts1,058,017 Members48,479 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 62 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 62 | On original gas tank mounts there are two bolts that you can unbolt to remove a part of the mount itself (not the straps) and the mount is still bolted to the frame. Were these made like this to remove the tank without removing torque tube. Looks pretty tight otherwise. I notice replacement mounts do not have these. | | |
