0 members (),
125
10
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | I installed a 2-speed w/park electric wiper motor from LMC a bunch of years ago. I needed a new switch so I ordered one from LMC.
The terminals of the new and old switches were labeled L (low speed), H (high speed), P (park) and B (Power).
I carefully noted the colors of the wires connected to the 4 terminals. I then lost the paper with the info on it!!!
Can anyone tell me which color wire (red, green, yellow, white) goes to which terminal (L, H, P, B) for this LMC setup?
I called LMC and the guy couldn't help.
Thanks!
1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Jan 2019 Posts: 2,243 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,243 | I have the LMC brand one hooked up in my truck. I will grab those colors for you the next time I am out there. | | | | | Joined: Mar 2014 Posts: 4,510 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,510 | General wiring convention is if you have a black wire, it will be ground. Yellow is high speed, green is low speed, white is park and red is 12v from your ignition "on" switch. Good luck
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
