0 members (), 123 guests, and 8 robots.
Topics128,186
Posts1,057,211
Members48,465
I installed a 2-speed w/park electric wiper motor from LMC a bunch of years ago. I needed a new switch so I ordered one from LMC.
The terminals of the new and old switches were labeled L (low speed), H (high speed), P (park) and B (Power).
I carefully noted the colors of the wires connected to the 4 terminals. I then lost the paper with the info on it!!!
Can anyone tell me which color wire (red, green, yellow, white) goes to which terminal (L, H, P, B) for this LMC setup?
I called LMC and the guy couldn't help.
Thanks!
I have the LMC brand one hooked up in my truck. I will grab those colors for you the next time I am out there.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Moderator, Electrical Bay
General wiring convention is if you have a black wire, it will be ground. Yellow is high speed, green is low speed, white is park and red is 12v from your ignition "on" switch. Good luck
~ Jon
