| | | Forums66 Topics128,209 Posts1,057,462 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2019 Posts: 22 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 22 | 1965 c10 long bed, stepside
I am in the process of rebuilding my bed, new angle strips, rear stake pockets etc. I am going to fit the fenders and steps to make sure I have everything before paint and body work. Were the original bolts for the fenders Phillips or clutch head. I did not take it apart, hence my question. Thank you.
1957 3100 - 1965 C10
~Brian
| | | | | Joined: Feb 2023 Posts: 387 'Bolter | | 'Bolter Joined: Feb 2023 Posts: 387 | I’m certain my 66 short stepside was original & it had Phillips head screws | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Having taken a few beds apart, I have removed only phillips head. | | | | | Joined: Jan 2019 Posts: 22 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 22 | Thank you very much for the replies I appreciate it.
~Brian
| | | | | Joined: Nov 2021 Posts: 1,258 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,258 | Philips. Just put mine back together. | | |
