| | | Forums66 Topics128,076 Posts1,055,920 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 26 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 26 | After installing my transmission ( Muncie 4 speed) after a clutch change, my speedometer did not work. It took me awhile to find the problem but it resulted that the cable connector had slipped up the cable shield when I removed it such that the end of the cable end was not deep enough into the transmission to engage the cable.
The transmission end speedometer connector is crimped to the cable shield. On mine, the cable connector was not crimped enough to keep the cable from slidding down the cable. I positioned the cable correctly to the connector and recrimped it. This solved my problem. | | |
