| | | Forums66 Topics128,052 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2022 Posts: 21 'Bolter | | 'Bolter Joined: Jun 2022 Posts: 21 | I just started working on 59 apache 3200. Working on door hinges and where they bolt to A-pillar. I am missing 4 of the 6 cage nuts and brackets. I have found the rectangular nuts online, however, not been able to locate the cage portion. Does anyone supply these that can be tacked in place? The panel itself is in decent shape and I'd rather not have to piece in replacement panel. Thanks in advance.
53 chevy 3100
| | | | | Joined: Sep 2020 Posts: 442 'Bolter | | 'Bolter Joined: Sep 2020 Posts: 442 |
Hank: 46 Chev 1/2ton shortbed 2023 Miata RF Club | | | | | Joined: May 2015 Posts: 11,036 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,036 | Restoration Specialties has those weld nuts also. You can buy them individually. LINK
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | |
