When replacing the rear wheel bearing with modern bearings, say Bower, Federal, Timken will I need to reinstall the inner deflector or retainer part # 5.392 and 5.816? This is just incase I forgot the first time. Is it possible to reuse the bearing if remove with a slide hammer. See attached.
Thanks Red frown
1950 Model 3104 5-Window
"Back In Time"
Follow in the DITY
