5 members (NJC, 2-Ton, GMCJammer51, 2 invisible),
71
Mod | | | Forums66 Topics128,263 Posts1,058,134 Members48,482 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 5 New Guy | | New Guy Joined: Jul 2007 Posts: 5 | Hey guys, I'm looking into maybe putting some 22.5" wheels on my truck, does anyone happen to know the bolt pattern off hand w/o me having to go and measure? | | | | | Joined: Nov 2005 Posts: 6,102 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,102 | Hy Kvette007, We require a tinsy bit more info, like what year and size truck you're talking about? | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | I'll bet my first born it's a '53 two ton with 5 window cab! I'll also bet I don't know the bolt pattern. Stuart | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Once you know what truck you have, do a search in the Big Bolts for wheels, we seem to cover all the wheel options every week or two.
Grigg | | | | | Joined: Jul 2007 Posts: 5 New Guy | | New Guy Joined: Jul 2007 Posts: 5 | Yeah, sorry about that, it's a 2 ton | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | try this thread: http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=6;t=001799#000005
You have 10 lugs on 7.25" circle. The center hole is probably 4.75", but check to be sure. If it is, then to use any newer wheels like you are looking for you will need some simple spacers.
If you do happen to have a center hole measurement of 5.25" they you are fine.
Grigg | | |
