1 members (Hanks custodian),
264
Mod | | | Forums66 Topics128,089 Posts1,056,139 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2020 Posts: 51 'Bolter | | 'Bolter Joined: Jul 2020 Posts: 51 | I have 2 push rods that I can not remove from the block. Engine is 54 235 with solid lifter. Project started as a valve adjustment but found out that the front two and back two rockers were not getting any oil. Should i pull side pan to check out? This is on # 3 cylinder. Did pull the rockers. Thanks for any advise. Dave | | | | | Joined: Feb 2019 Posts: 4,480 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,480 | You can remove the pushrod cover (side cover) and that will give you full access to the pushrods, but be prepared to replace the gasket.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | |
