8 members (Nick in Manitou, GMCJammer51, 68ironhead, Ridgeback, 66flea, 3B, KEVINSKI, 1 invisible), 99 guests, and 2 robots.
Topics128,169
Posts1,057,033
Members48,458
Where can I locate a set of nuts for my 235 rod bearing bolts. Also, is there an updated, say self locking type nut, or the regular nut with the keeper would be sufficient?
Ol'55, It would help folks provide helpful info if you let us know what year your 235 is. wink
~ Dan
1951 Chevy 3 window 3100
OK I am just gonna think the clue is in the posters name. Pal nuts were used up to and including 1955. Think a light duty lock nut. Available from Classic and others. I am not aware of self "locking" rod nuts. I hope this is helpful.
Steve H
For more modern locking nuts try HERE. You'll need to measure the diameter and thread pitch to get the right size, of course.
3/8-24 Grade 8 nut- - - - -don't bother with any sort of locking device. Torque keeps rod nuts tight- - - -not some kind of Mickey Mouse plastic lock ring, Pal Nut, or cotter pin. If you're determined to get obsessive-compulsive about it, use a drop of red LocTite. Heat the nut to 500+ degrees F. if you ever need to take it apart again. That's how we built our 700+ HP small block V8s that ran 7K RPM or more twice a lap.
Ok , sounds great so 3/8-24 Grade 8 nut torqued at 35 ft. lbs.?
ARP Hex Nuts 200-8634
Mike
Yes, or you can pay three times the price for the same nut with the ARP name on it. Does anybody think they make their own hardware?
www.ebay.com/itm/266622198621? Less than a dollar each with free shipping.
1 Offline
So, why did the factory use pal nuts on the dipper engines and drop them on the full pressure engines? They weren't free and each engine needed 12 of them.
1951 3800 1-ton
In the DITY Gallery
Stupidity and over-engineering everything. Why did they use four different size main bearings on engines producing less than 100 HP at the flywheel?
Mike
My guess as to why they used pal nuts on dipper engines, but stopped using them on engines with insert connecting rod bearing was due to the possibility to run the engine with babbitt bearings longer before you ran out of bearing material. Seems to me that a well worn, loose babbitt connecting rod is more likely to rattle a connecting rod nut loose if it weren't held fast by a pal nut. Add to the scenario the extra stress on everything caused by a loose dipper constantly having a jet nozzle spraying oil at it.
BTW, it has been my experience that GM did not stop using pal nuts when the dipper engines were phased out. They used them for a few years on insert bearing engines.
I've found lots of Palnuts in the bottom of oil pans, buried in a layer of sludge. They were notorious for coming unglued- - - -which makes me wonder how effective they were at keeping rod nuts tight. They were also used on MOPAR engines- - - -which were all equipped with insert bearings. Even a slight overtorque of that sheet metal nut would strip it and make it prone to come off.
The Book says to install new ones and not to reuse them. Those are likely the ones that end up in the sludge receptacle. I have found them there myself a few times. One time I found one, but there weren't any missing on the connecting rods. Goober must not have clean out the oil pan in 1954 when he peeled some shims during a half-hearted overhaul.
I don't use them on insert bearing engines even if that came with them, but I won't drive one that has a rod knock either.
With the new nuts installed what is the torque again?
1 Offline
I once had a BMW 320i. On changing the oil one day, on a whim I stuck my finger in the drain hole and felt something move. Got a magnet and fished out a con rod nut.... aaach! What to do? By this time the car had 100,000 + miles and I figured if it was going to come apart it would have already. But I worried the issue for some time, considered pulling the pan to look. But didn't. Sold the car with 250,000 mi. still running well.
1951 3800 1-ton
In the DITY Gallery
24601
24601
Tommy -- Same experience. But with a backhoe diesel engine. Found the bottom inch of a push rod. Engine ran great.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
PAL nuts, broken adjuster ball from a rocker, the remnants of the O ring seals from valves, all in oil pan sludge. But, they kept going and going and going, lol.
Mike
To get back to your question, see the screen shot below from a 1955 2nd Series Truck Shop Manual for your rod bolt torque specs. wink
~ Dan
Actually, they do.
